Help. Drivers door will only open from inside,..door apart and all looks OK
Yes, as I mentioned, I don't have the short piece with a 90 degree at both ends (Rave shows that on rear doors),....I have the longer piece bent 90 degrees at the top and threaded into white plastic at the bottom (not bent 90 degrees)
So, what now guys?
So, what now guys?
This is pretty simple stuff.
Does the linkage move when you pull the handle from the outside? (might be easier to have someone else pull it while you observe)
If no, the handle is broken. If yes, see below.
Detach the linkage from the handle. Use a screwdriver to trip the latch as if the door were closed. Can you pull the linkage far enough to open the latch? (may need to pull on the latch while pulling the linkage) If yes, your linkage is out of adjustment or stripped. If no, your door latch is damaged and needs to come out for repair or replacement.
Long story short,....it now works,..........however,.......I still have no door lock function from the key in the door slot,......but door locks work fine from the key remote. Star end of the door handle cross shaft is fine,....and the white nylon cross in the door/lock/actuator assembly looks ok.
rjsdavis
06-26-2016 12:20 PM
1998DiscoverySE
02-08-2012 02:41 PM
marlymarl
07-28-2005 12:23 AM
