Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-02-2012, 07:46 AM
Senior Member
Google search says 2 things, forum results in MAF being the problem, but then theres this:
OBDII Code P0734 LAND-ROVER - Gear 4 Incorrect Ratio | Engine-Codes.com
I'd say the engine-codes description fits your symptoms but someone who knows for sure will chime in soon
__________________
Black 2000 Disco II
Factory brushguard
3" Terrafirma + s. damper
Terrafirma F/R Diff Guards
Terrafirma Fuel Tank Guard
D90 ujoint propshaft
Bosche Plat +4 + blu wires
Amsoil coolant/diffs/xfer
Shell Rotella + Filtermag
Rain X Repel wiper mod
DI CDL
285/75/R16 Guard Dog MT's
NO CEL OR AMIGOS
Old 02-02-2012, 07:55 AM
Send a message via Skype™ to Disco Mike
A 734 fault code, 4th. gear out of ratio, is one of a couple codes that when they show up together will indicate the MAF is dead. The other indicator is if you get both banks running too rich or too lean, then it is a MAF for sure.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Senior Member
734 is a transmission ECU code, and :
P0734 is detected when A/T cannot be shifted to the 4th gear position even if electrical circuit is good.
So that would explain high RPMs. Time to focus on tranny (fluid level, fluid and filter change, etc.)
__________________
Old 02-03-2012, 06:24 PM
far4cges's Avatar
Member
My shift points and idle are a mess also when cold in the morning. On start up it races up and then sits about 1000 rpm, when I get going it will run about 2500 rpm at 65 and isn't kicking into 4th gear. Once it warms up it goes into 4th with no issues and runs about 2000 rpm at 65.
So MAF or tranny fluid? Or both?
__________________
2004 Discovery SE
"Dark Helmet"
IYAAYAS
Old 02-03-2012, 10:16 PM
lordmorpheus's Avatar
Senior Member
Neither, more than likely. Savanna will surely jump in with a quote from the RAVE, as I am too tired from work to find it there, but I know the torque converter does not lock up until the engine has reached operating temperature, and the same may be true about 4th gear also.
Driving home from work, I only take the highway if the engine is at normal operating temperature. Normal roads if not. My work is about 3 minutes from the highway on ramp, and I am only on the highway for a couple of miles. I would just rather keep the revs below 2000.
On cold startups, mine starts at 1,200 RPM, then drops to 1,000 in less than 30 seconds, and then to 750~ after a minute or so. That is normal.
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Old 02-04-2012, 07:32 AM
Senior Member
On the D2, the tranny ECU gets all sorts of inputs from the ECU and other sensors, and computes when shift points should happen, and has an adaptive pattern it stores and compares, etc. It will decide when it is best for the machine to shift. On the D1 it is simpler, no 4th gear until about 53 mph.
__________________
Old 02-04-2012, 02:22 PM
DiscoRover007's Avatar
Senior Member
Guys what's the normal rpm range for idle on the 03-04 4.6? I think I might be idling too high.
__________________
2003 Discovery II SE
Check out the gallery!
http://landroverforums.com/forum/mem...discovery-522/
Upgrades:
HID head light bulbs
2" Terrafirma shocks and springs, medium kit,
Terrafirma steering damper
Rebuilt Drive Shaft
275/65/18 BFG Goodrich A/T TKO's
Repairs:
New HG, intake, valve cover and exhaust gaskets, new spark plugs, green coolant, transmission service
130,000 miles in the death range and still chugging
Old 02-04-2012, 04:51 PM
far4cges's Avatar
Member
Well thanks LM, your situation is an exact replica of mine. If this is normal I will add it to the list right after the other "normal Disco quirks"
1) feathering the gas to avoid banging the tranny around
2) only using the cruise control when going for a longer than ten minute trip on the highway
3) on cold start be patient with the tranny ECU
I am learning more with every little issue.
__________________
2004 Discovery SE
"Dark Helmet"
IYAAYAS
Old 02-04-2012, 04:56 PM
far4cges's Avatar
Member
Quote:
Well I don't know if it is normal but… my '04 4.6 idles @ 1K RPM for a few minutes on cold start, then down to steady-state at 750. When driving at 60-65 I run about 2000-2250. Unless cold then it is around 2500-2750.
__________________
2004 Discovery SE
"Dark Helmet"
IYAAYAS
Old 02-04-2012, 09:45 PM
Senior Member
Hmm alright thanks man. I was idling at 1200 at cold start today and settled to about a 1000 rpm. On the highway I could hit 70 mph at about 2500 rpm.
__________________
Upgrades:
Rebuilt Drive Shaft
Repairs:
Tags
2004, 99, discovery, gears, high, highway, land, points, problem, problems, range, rover, rpm, shift, speeds, sport
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
