How to Change Fuel Filter (Location)
Yes they are. The system does not return the fuel to the tank like what we are used to. Less circulating fuel mean less hydrocarbon emissions(gas vapor) accumulating in the tank. Less circulating fuel aslo means the garbage that makes it into your tank from the gas station, will settle and and not be stirred up as much as it would with a conventional system constantly circulating back to the tank, therefor no need for a filter. There is a pick-up screen or sock, on the pump to halt major debris from flowing.
meineke495
11-29-2007 04:48 PM
