How to determine if my steering damper is shot??
Old 06-25-2015, 05:43 AM
Lowest Bidder's Avatar
I maybe wildly off base here so please pardon my ignorance, but isn't the steering damper only there to prevent the wheels from turning the steering wheel violently while off-roading? I was under the impression that the steering damper will not dampen vibrations produced by the front axle or steering mechanism.
At any rate, I'm 100% with you guys when you're saying if there's vibration up front, it's better to find the cause and repair it than to mask it with the damper.
Old 06-25-2015, 06:28 AM
drowssap's Avatar
you are correct, you are wildly off base
Old 06-25-2015, 12:47 PM
X1. if it vibrates so without the steering damper it will no doubt feel worse and then start searching hard for the source of the vibes.
Old 06-29-2015, 06:29 AM
Cool! You learn something everyday
Old 06-30-2015, 12:26 PM
chubbs878's Avatar
Default did you go over the checklist?
Originally Posted by offroadfrance
i agree with drowssap, the damper can disguise many steering defects. Firstly check any slack in the steering box as it adjustable.
The things to check.
Track control and drag link ball ends.
Top and bottom steering ball ends both sides.
Cv joints.
Tire balance.
Radius arm bushes.
Panhard rod bushes.
Rear watts linkage bushes.
Old 06-30-2015, 02:23 PM
bcolins's Avatar
Originally Posted by chubbs878
wondering if the steering boxes are similar to the old recirculating ball units used in the older Mercedes. You could tighten the adjustment screw and it would improve the slop at the center point,...but once you moved past that worn center point,....the mechanism would begin to bind,....and often would not return to center on its own.
Old 06-30-2015, 03:22 PM
acg's Avatar
acg
acg is offline
Good info here:
https://landroverforums.com/forum/di...ing-box-66302/
https://landroverforums.com/forum/di...upposed-58657/
Old 06-30-2015, 03:59 PM
Alphamale's Avatar
Yes, similar. The workings in the box are like a worm drive and just as a worm drives ware in the most used area (centre) so it is here. The result is that if you remove a lot of the slack in the straight ahead position you could find that at either lock the steering will feel heavy as the mechanism is to tight.
The best thing is to adjust it gradually, loosen off the lock nut and with a 5mm allen key tighten the adjustment screw 2 turns then test it. Repeat as necessary to take out as much of the free play at the centre without compromising the free play at each lock.
NabisOne
02-16-2013 08:19 PM
TRIARII
07-21-2012 01:46 PM
Disco Fuego
04-21-2012 11:17 AM
hallfleming
10-17-2011 09:56 PM
thehun
03-10-2011 08:11 AM
Quick Reply: How to determine if my steering damper is shot??
