how to disconnect auto leveling warning system?
i had the air pump go out, so i disconnected the lines from the pump and rigged up a manula system whereby i can fill the bags with any old airpump. the prblem is, the autoleveing malfunction light is now on, and the dinger rings constantly. i would take out the fuse, but on a 2000, the fuse also runs the anti lock breaks. ayone know whih line to sip or what you ca do to disconnect the auto leveling waring dinger?
RE: how to disconnect auto leveling warning system?
so there's nothing you can cut to stop the dinging? my closest dealer is 2+ hours away and i think i'll go crazy driving it that far to be reprogrammed.
edit: solution, if you plug the compressor back in but leave the lines unplugged, it fixes it. great solution. with under $5.00 invested, i have a new air system!
ORIGINAL: Landzu
Check Atlantic British I thing they have a bypass when you go with springs.
chadbormann: do you have any indy rover shops by you? You can call Atlantic british and they will locate the closest place that has an autologic scanner...
R anger over
03-19-2013 02:58 PM
