How do i work the cruise control?
Old 11-19-2008, 10:25 AM
princelumber's Avatar
Default How do i work the cruise control?
So I watched the video, but I didn't get an owners manual.
I figured out that the little skateboard on the dash is the cruise control, but when I turn it on and click the little steering wheel switch...nothing.
Do I need to double click it? Hold it for a minute? I tried as many options as possible but ran out of freeway last night.
Help me out so I know if I need to check that brake pedal/hose connection that I read about in the other threads.
Also, I didn't hear any clicking or any noise when I tried to engage it.
Thanks a bunch.
p.s. I'm on two weeks of rover ownership and LOVE it.
Old 11-19-2008, 11:07 AM
AK Rover's Avatar
Default RE: How do i work the cruise control?
The skateboard you referred to is actually supposed to represent your vehicle traveling down the road and that is your cruise control master switch. That must be turned on for the cruise control to work. Make sure that the orange light on the master switch illuminates when you push it. If not, I would suspect you have a bad switch and replace that. That was one of the problems the cruise on my 97 had. After checking the switch, trace all the vacuum lines and make sure they are all in good condition. A vacuum leak anywhere in the system will prevent the cruise from working.
Old 11-19-2008, 11:39 AM
jmrivera's Avatar
From the Owner's Manual (I have a 03 so I am not familiar other than the manual)
CRUISE CONTROL
Cruise control enables the driver to maintain a
constant road speed without using the
accelerator pedal. This is particularly useful
for freeway cruising, or for any journey where
a constant speed can be maintained for a
lengthy period.
The cruise control system has three switches;
a master switch on the fascia panel and two
control switches marked ’SET +’ and ’RES -’
mounted on the steering column.
To operate
1. Press the master switch on the fascia
panel (arrowed in illustration) - the
indicator light in the switch illuminates
whenever the switch is pressed to the ’on’
position.
2. Accelerate until the desired speed is
reached. This must be above the system’s
minimum operational speed of 28 mph
(45 km/h).
3. Press the ’SET +’ switch to set the vehicle
speed in the system’s memory. Cruise
control will now maintain that road speed
without the need for manual operation of
the accelerator.
With cruise control operating, speed can be
increased temporarily, e.g. for overtaking, by
normal use of the accelerator. When the
accelerator is released, road speed will return
to the selected cruising speed.
Old 11-19-2008, 12:44 PM
thanks. The cruise engage switch (skateboard on the dash) lights up just fine. I'm guessing that i gotta dig into that hose mentioned in the other threads.
Old 11-19-2008, 01:16 PM
salve7's Avatar
Also be sure that you are pulling the switch on the steering wheel towards yourself instead of pushing it back towards the dash!
Bllourias (06-09-2022)
Old 11-19-2008, 02:17 PM
hazletbassist89's Avatar
99.9% sure you have a vacuum leak. It happens in almost every Disco. Goop them up with something to seal them or just buy new ones for like $10-15 and then you should have no problems
Old 11-19-2008, 06:53 PM
ORIGINAL: princelumber
That "skateboard" is the universal worldwide symbol for a motorway. It is a bridge across a road.
Vacum leaks, check for vacum leaks.
Old 06-09-2022, 01:32 PM
Bllourias's Avatar
3rd Gear
Default No indicator light for cruise
I am also having problems with my D2 cruise control (CC)
once I press the Cruise Switch on the dashboard, I do not get any light illumination on the instrument cluster. I have changed m6 switch twice, so I three switches in my possession. I attempted to see where the CC illumination location on the instrument cluster; however, AllData says the only illumination for CC is BEHIND the instrument cluster.
My ultimate question is "How do I trace the wires to see if something is shorted out?"
CRUISE CONTROL
lengthy period.
To operate
position.
(45 km/h).
the accelerator.
Old 06-09-2022, 02:42 PM
Extinct's Avatar
Received 1,402 Likes on 1,002 Posts
Download the Rave Manual, find the page with the cruise control wiring diagram on it. Link at the top of the section.
Old 06-09-2022, 03:39 PM
rynoman1's Avatar
I couldn't get my cruise control to engage when I purchased mine... after some time with dead ends on troubleshooting, I noticed the 3rd brake light, the one on the top of rear door glass was burned out. I replaced it with new bulb and cruise started working... so if your rear door brake light is burned out that will be your problem
Quick Reply: How do i work the cruise control?
