Changing discs/rotors on 2000 Disco II
Old 06-18-2011, 09:14 AM
mac_daddy's Avatar
5th Gear
Default Changing discs/rotors on 2000 Disco II
Does anyone have a good write up on changing the discs/rotors on 2000 Disco IIs?
Old 06-18-2011, 10:43 AM
mwindth's Avatar
Hey Mac_daddy...here is the LR shop manual with full details: land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
Super easy by the way...remember to use Dot 4 fluid.
Old 06-18-2011, 11:18 AM
souljad9's Avatar
take off wheels, unbolt caliper, take out set screw, pull off rotor. Quite easy.
Old 06-18-2011, 12:38 PM
Why are you changing the rotors, who's pads and rotors are you going to install?
Old 06-19-2011, 09:29 AM
mac_daddy's Avatar
5th Gear
Old 06-19-2011, 09:30 AM
mac_daddy's Avatar
5th Gear
Thanks, I figured it was something like that. Was just curious if there was anything particular with the land rover that I should look out for.
Old 06-19-2011, 09:31 AM
mac_daddy's Avatar
5th Gear
Because they're very worn and I need to do the pads anyways. Thought I'd just do 2 birds with 1 stone. I didn't have a particular manufacturer in mind, can you recommend one?
Old 06-19-2011, 11:04 AM
buick215's Avatar
EBC or DBA rotors and ceramic Akebono brake pads.
Old 06-19-2011, 11:16 AM
I am real big on the Akebono ceramic pads, stop better, last longer, no dust, no squeaks and no 3 Amigo codes.
Rotors I will leave up to you.
Old 06-19-2011, 04:19 PM
mac_daddy's Avatar
5th Gear
sounds like akebono is the way to go...
Quick Reply: Changing discs/rotors on 2000 Disco II
