How to tell if the radiator is working (Not Clogged)
Old 02-24-2012, 02:52 PM
I'd think maybe thermostat is not opening right. It has to allow water to flow through the system to get hot water into the radiator, don't recall if you changed stat, if you did not use OEM that may be a problem, there have been reports of aftermarket not opening soon enough. Belt route proper on water pump?
Old 02-27-2012, 07:09 PM
rimasco's Avatar
Hey Buzz.. whats the proper belt route on the water pump?? im 99% sure mine is correct but.. what the heck
Old 02-27-2012, 08:42 PM
see attached from RAVE.
File Type: pdf
Old 10-29-2012, 09:48 AM
dparham's Avatar
Just a note I learned way back when.. when putting on new belt on discovery 03 when I didnt have a diagram... I looked at pulleys... if they had teeth, then teeth side on belt faces toothed pulleys thus smooth on smooth... was pretty self explanatory at that point... I ended with the pulley to left ( Alternator ) of A/C pulley while holding belt tensioner loose .... in my experience was pretty easy ... might need cheater bar on wrench if upper arm strength is at a minimum.... Im 5'8" and 220lbs of mean Texas now Floridian ( dont tell my fellow Texans! lol ) so I didnt need the cheater bar... lol
Old 10-29-2012, 01:41 PM
jfall's Avatar
Old 10-29-2012, 01:42 PM
jfall's Avatar
jtsmeed
03-17-2014 10:49 PM
marjac
12-06-2009 05:28 PM
mherson
10-29-2009 10:54 PM
rodacutta
10-20-2009 01:43 PM
sfxgamer
04-23-2008 07:36 PM
Quick Reply: How to tell if the radiator is working (Not Clogged)
