I need a replacement black fender flare treatment
Whatever they're called, I need one. I was driving today in high winds and it blew off somewhere in a 200 mile stretch. It is the black foam-type plastic fender extension behind the rear passenger side door. Where do I find just the part I need and not a whole set? Thanks.
The biggest issue is the texture. They tend to get rough with age. You can always use something like Forever Black. I've had good success with it in the past. Others have gone so far as to spray paint them black so they'll match. You should probably do a search here on the forum. I'm certain this topic has been discussed in the past.
Cheers,
Paul
Cheers,
Paul
Cheers,
Paul
Cheers,
Paul
