Idler Pulley Whine
Idler Pulley Whine
Ok, so I just replaced my belt (2001 DII 142,000) and I yanked the 70mm idler to check for any damage. No visible damage so I tightened her down and cranked the engine. I have a noticeable whine and I can pin it to the 70mm idler just below the tensioner pulley.
I loosened the nut on the idler a bit to see if that would work but I still have the whine. Do I still have it too tight? There are no torque settings in RAVE for that particular Idler pulley. Has anyone here put a torque wrench to that pulley before and if so what setting did you use? If not, how tight is too tight and how would I know if it were too loose? I still think there might be a chance that I have it wrenched too tight. I just don't want the sucker coming off on me.
Thanks for any feedback.
