Immobiliser bypass
Immobiliser bypass
Hi
I was told that if your spider box (immobiliser) fails, then in order to bypas it, one must connect a wire from the ignition switch (white wire) to the stop solenoid. The spider box is a common problem on the landrover which results in the landy cutting off.Can someone tell me what and where is this stop solenoid that they talking about.
Many thanks
Suveer
Many thanks
Suveer
2000, box, bypass, bypassing, defender, discovery, ignition, ii, immobiliser, immobilizer, immoboliser, imobilizer, land, range, removal, rover, spider
