Instrument Cluster and grounds
Past month or so when start my Disco the battery light is on. I blip the throttle and it goes away and doesn't return until its sit overnight at least. I have a newer alt and battery from this year so don't think this is it (and the alt is not a rebuilt one from any autoparts store, its a genuine LR replacement). This didn't start until the temp got really cold but I figured it might be a ground that needs cleaning. Wasn't to worried as I don't drive it to often.
Today I started it and noticed the battery light wasn't on as I was suspecting. When I got in I realized the entire instrument cluster was not working. The lights behind it were on but all needles were down. Turned on the turn signal and initially it didn't work but when I tried it a second time all of the sudden the entire dash started working again. Looking over some post and looking at the RAVE and see mentions which fuses to check but don't think that is it (unless they came loose), bad instrument board possibly, or my thought is bad ground. It appears there is one under the driver side carpet by the foot rest pedal area.
Figure these are my places to start but curious if anyone else had similar issues or maybe something else (or other ground) it could possibly be? I know tracking down electrical stuff can be fun
Thanks
Thanks
Thanks
Thanks
PS Check the connections on the alternator are also clean and making good contact.
Thanks
Thanks
riko suave
03-18-2009 04:34 PM
CandiMan
10-30-2008 01:39 AM
Greg
08-08-2007 04:47 AM
