Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-04-2012, 01:08 PM
FightOnUSC79's Avatar
Senior Member
WEST.WEST.YALL John_R_Scott
Default I've Got Codes and Coolant
Driving home from breakfast and I smell coolant then get the following codes.
P1300
P0303
P0305
P0307
P0130
THey are misfires and an o2 sensor warning from what i can find, but the Coolant is running off the top of the valve cover from what looks like the throttle body, which seems like the standard issue from my searches here.
Would that Gasket going bad lead to the codes?
__________________
2004 Disco II SE 110K Miles on truck/48 on engine:
Rebuilt front drive shaft / mikes 60k service / new shoes / HG / 8mm STI wires / Akebono pads front and rear / New Rotors all around / OME Steering Stabilizer / Ultra Gauge
In the future: HLC Front and rear bumpers - OME Suspension - Safari Rack with Lights - Let the saving begin
Arizona Land Rover Owners Member AZLRO.org
Fight On USC!
Old 02-04-2012, 04:06 PM
Senior Member
Coolant Resivour was down about an inch from full line, so my next question is could the throttle body heater gasket failure cause that much loss in a matter of 10 miles?
__________________
Fight On USC!
Old 02-04-2012, 04:40 PM
DiscoRover007's Avatar
Senior Member
I don't think the throttle body leak would cause many O2 codes unless the coolant was shorting out your sensor. Which is definitely possible if you are leaking from the HG or valve covers. The throttle body heater plate is a very easy fix and can be done in about an hour or less. Or you can bypass it.
__________________
2003 Discovery II SE
Check out the gallery!
http://landroverforums.com/forum/mem...discovery-522/
Upgrades:
HID head light bulbs
2" Terrafirma shocks and springs, medium kit,
Terrafirma steering damper
Rebuilt Drive Shaft
275/65/18 BFG Goodrich A/T TKO's
Repairs:
New HG, intake, valve cover and exhaust gaskets, new spark plugs, green coolant, transmission service
130,000 miles in the death range and still chugging
Old 02-04-2012, 04:49 PM
Senior Member
I checked the oil for fluid and found none, but the throttle body plate is definitely crusty with dex looking crystal like I've seen others post. I'll start there, but am bypassing it until the kit shows from AB.
Edit: I meant no coolant in the oil, but I did see the coolant on the O2 sensor which may explain the codes. I guess I'm on a seek and destro mission for leaks in the AM
__________________
Fight On USC!
Old 02-04-2012, 06:04 PM
Senior Member
Coolant hose to TB could certainly blow out a lot of coolant in 10 miles. Keep in mind that it is a safety item to prevent icing up the throttle body and sticking with throttle on. If it should happen be prepared to shove in "N" and kill ignition. Here's the layout so you can look for all the leaks.
__________________
Old 02-04-2012, 06:11 PM
Senior Member
Quote:
Thanks Buzz, After checking that diagram the only other source of leak outside of the TB looks to be Hoses to the heater core (if I'm not mistaken) but that would be a leak on the passenger side; correct? Also, I'm definitely not leaving it bypassed longer than it takes for the part to get here.
Thanks again
__________________
Fight On USC!
Old 02-04-2012, 06:13 PM
Senior Member
Usually you'll have wet floor with a core leak, and you will smell coolant inside.
__________________
Old 02-04-2012, 06:19 PM
Senior Member
I have neither syptom, but again it just started and I brought her home immediately while watching the ultra gauge, which never went above the normal 204 stopped at a red light. I'll know more tomorrow after I bypass and watch for leaks. It needed the new TB kit, so I'm kicking myself in the arse for not doing already.
__________________
Fight On USC!
Old 02-04-2012, 09:41 PM
Senior Member
Actually I think the usual "coolant in oil check" isn't really applicable to Discovery's. I mean it is but is not a reliable test. I had a HG leak, no coolant in oil. Currently have a weeping HG that is shorting out my precat passenger side O2, no coolant and oil mix. Sounds like you've just got a TB leak but just letting you know.
__________________
Upgrades:
Rebuilt Drive Shaft
Repairs:
Old 02-04-2012, 09:52 PM
Senior Member
You have an external HG leak, but an internal will make milkshakes in the oil pan (plus a lot of smoke), the valve cover oil fill can show butter on the bottom side, valley pan can also leak into the oil.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
