Key Lock Remote - Works, most of the time
Old 05-21-2012, 01:13 AM
Rover_Hokie's Avatar
Default Key Lock Remote - Works, most of the time
My driver's door lock actuator has not worked with the remote for sometime, but I have been able to use the remote and the remaining doors would unlock/lock. Now, I have noticed that even when I use the remote to open the doors it will not work after the D2 has sit overnight, and maybe for a long period during the day (really haven't timed it yet). The remote does not work at all, at least until I unlock the driver's door with the key, then the remote will lock and unlock the doors again. I do see the red light on the remote activating, but no indication that the rover has received that signal based on any action or noise I am use to when the locks are activated.
I go to the store, or to dinner, come out and the remote works on all doors but the driver's door as before, and most any other time except the first time I try to use it each day, be it 7AM or 1PM. If it has been sitting since the prior day, the remote does not unlock any doors, you hear no locks being activated and the signal lights do not flash. Any ideas!
Old 05-21-2012, 04:13 AM
New battery in remote as a first step. The attached wiring diagrams show that all these things connect directly to the the BCU, except the lock motors, which are driven by reversing relays of the IDM. Perhaps a connector (those tiny lawyer-sized fine print numbers) is corroded, and has a mind of its own. See electrical library for photos of every connector location by number.
File Type: pdf
Old 05-21-2012, 03:53 PM
slanginsanjuan's Avatar
i have the same problem specific to the drivers door. i was thinking it was mechanical. also hatch doesnt open except from inside. ill get to that soon.
discoland
09-06-2023 01:42 AM
aguison
09-09-2012 10:42 PM
hilltoppersx
ROAMING WITH FRIENDS
12-07-2010 05:48 PM
RROJ
10-09-2010 07:39 AM
RROJ
10-08-2010 09:56 PM
Quick Reply: Key Lock Remote - Works, most of the time
