keys locked in! plz help
hi, I locked my keys inside my 04 LR Discovery, call a pro to open it, he managed to lift the lock pin in the door, but door wouldn't open.
Then, he somehow put a straight metal stick to reach the unlock switch in dash and pressed it, but still no luck.
Why the doors would unlock?
dealer tells me a one week wait
Any help would be greatly appreciated.
thanks
thanks
1-You can write down your VIN# and go to the dealer and they can make you a new key using the VIN#.
2-You can break a window.
If you closed the door on the remote and it is pressing on the lock button then the truck probabaly went into "super lock", that is when the doors are deadbolted shut and you will never get it open without a key or breaking a window.
wow, i must be surprised, i just came from a trip and my Disco II 03 is locked, i have the keys but battery dieds so maybe if i find a way to connect an external battery just to activate the alarm can work but i do not find any connection to do that, any clue where to place the external power?
Thanks and hope to not brake any glass before find another way to open it.
Already open
Ok, let me explain, the door does not work for key, it was damaged weeks ago and i just openend with remote control, once the battery died there was not any way to open it with the key so i used a large screw, open the hood, power the dead battery and unlock the truck with the remote control, that´s it, i really do not know if i was lucky but right now there is a new battery and door lock fixed.
I also do not understand why the truck comes with just one lock on driver door, it looks like a trap for the owner.
Thanks all for the support.
Raul...
Raul...
