If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
My 04 Discovery is throwing a knock sensor code that won't go seem to go away by clearing it. If I go ahead and replace the sensor, do I have to stick with OEM or are there aftermarket (cheaper) ones available?
__________________
2004 Land Rover Discover HSE - 85k
I bought the truck about a month ago and am finishing up my second tank of 93 (Exxon). I have little confidence that the previous owner was using a higher octane and suspected that that could be tripping the sensor. However, I can't seem to clear out the code and am due for an inspection in February (of course). I'm also not certain as to when the truck last had a tuneup.
__________________
and which code? Rock Auto has sensors for $30 - $34. Knock sensors are basically cystals tuned to the noise frequency of a ping, and they produce a voltage at that point, which the ECU detects and deals with. Not a complex gizmo like an MAF sensor.
Thanks. Code is P0327 (Knock Sensor 1 - Circuit Low Input (Bank1)). I believe Bank 1 is the right side, if I'm looking at the front of the truck, correct?
__________________
Left and right is ALWAYS from sitting in the driving position, always and it makes no difference what car or where in the world it is.
So right side is the left of the engine looking at it from the front.
All parts of every car are located inthe same manor. All right side parts are on the right hand side..such as fender/doors/1/4 panel...and left are as such. People who don't understand this are just insane to talk to. They look at a car from the front and assume that the right fender is on the left, because it's to their left. Try and explain drivers side and passengers side......their first question is "What if it's a right hand drive car" Hence it's still on the right side !!!!!!
Reason: better expanation
