Leaning
Old 05-04-2010, 07:47 PM
reddisco's Avatar
Default Leaning
New shocks last year on 1997 Disco. Significant lean to passenger side. Also front passenger side wheel well is almost 2 inches lower than driver side. Could this be a sway bar issue? or coil springs or bushings? Drives fine. On the beach it feels loose at the top of each bump. Any ideas?
Old 05-04-2010, 07:55 PM
tweakrover's Avatar
disconnect your sway bars and if its still leaning put your girl on a diet.
Old 05-05-2010, 07:32 AM
Sounds like a broken spring, time to install that lift you always wanted.
Old 05-05-2010, 12:02 PM
When you put in the shocks, did you re-use the original springs?
Old 05-06-2010, 05:17 PM
tweakrover's Avatar
shocks don't matter with ride height they just slow the travel of the suspention
Old 05-07-2010, 08:29 AM
reddisco's Avatar
Just replaced shocks, not springs. Do I reconnect the sway bar?
Old 05-07-2010, 08:44 AM
Long Haul's Avatar
If the sway bar isnt why its leaning i would put it back on.
Sound more like a broken or bad spring to be leaning that much.
Old 05-07-2010, 09:55 AM
Check your springs, you have one that has collapsed or is broken.
Sway bars and shocks will not cause this to happen.
jrm123180
02-09-2010 11:17 AM
billygoat
12-15-2009 07:12 PM
BayouDisco
11-08-2008 12:21 PM
rphotographer
11-13-2007 07:12 PM
shallowrunner
07-14-2005 01:31 AM
Quick Reply: Leaning
