LED H7 headlight bulbs/lamps
I have purchased some replacement headlamp H7 lamps for the D2 facelift. I'm hoping they cut down some of the unnecessary heat on the polycarbonate lens and also give a good light spectrum. I'll post how they perform after I've fitted them and they have been in place for a week or two. They also consume less power but not much as they are 50 watts each vs 55 watts standard lamps.
Take a look at these 1x Lampada 50W H7 472 CREE LED WHITE 6500K BULB HEADLIGHT CANBUS ERROR FREE NEW | eBay
problem with a facelift they require 4# for the dip and main beam lights.
Read up here:
LED Headlights or NOT
The 1800LM version seems to be a good fit for the low beam, but leaves a bit to be desired for the high beam.
This is a 3200LM (supposedly) version. They market as 6400LM because there's two which is silly, but I digress. I picked eBay France, since you're in France and whatnot.
2015 NEW 72W 6400LM H7 Cree LED Headlight Conversion KIT Lamp Bulb 3000K 6000K | eBay
