Why did I miss this? DII Vibration
Old 09-18-2012, 03:10 PM
Spencerfitch's Avatar
Default Why did I miss this? DII Vibration
So total... To fix my vibration
Front drive shaft rebuild 100$
Front driveshaft replacement 300$
Muffler that driveshaft took out 185$
Seems like It somehow took out 02 also $$ ??
Now, thankfully shop didn't charge me but they cannot find the source of the vibration, its not the tires there thinking its internal.. Bearing in Transfercase or Tranns?
So there sending me to a driveline shop that they have sent other land rovers to. Hopefully its nothing too expensive.. I have to say its the first time Im letting others diagnosing my problems instead of my self and man it feels good. When you got money than time its all you can do.
Old 09-18-2012, 04:15 PM
jeffh's Avatar
so NO idea what your vibration is. i.e. there is no description of it in this thread....
having said that.... hoe about tire balance, rear roto-flex.
Old 09-18-2012, 05:40 PM
It vibrates bad from about 30-40 and then a little less from then on.
New driveshaft seems to have changed the frequency, I'm going to personally check the rear roto then it's off to a shop.
Old 09-18-2012, 08:29 PM
The output shaft on the t-case can go bad, the bearings I mean and it will vibrate.
Remove the front driveshaft, drive it, is it gone?
Old 09-18-2012, 08:56 PM
Oh idlove to, but it ain't gonna drive with an open diff
Old 09-18-2012, 09:09 PM
Racer X's Avatar
You have a 98, just engage the CDL.
Old 09-18-2012, 09:14 PM
wyrdvans's Avatar
Check the motor and transmission mounts. After replacing mine, three of the four mounts were separated, the last vibration disappeared.
Old 09-18-2012, 09:27 PM
What year is your DII?
Dont you have the CDL nipple on your t-case?
I thought you had a '01, but I've almost been wrong before.
Old 09-18-2012, 10:20 PM
Sorry 03. Best of the best.. I'm considering getting the CDL and then doing my own diagnostics since I want CDL anyways
Old 09-23-2012, 06:16 PM
aarongregor's Avatar
what is vibrating?
Quick Reply: Why did I miss this? DII Vibration
