M and S flash but gear selection not illuminated.
I just tried to clear it again. It cleared but then threw the code 3 seconds after starting without taking it out of park. I am curious, I would like to take a shot at repairing (cleaning) mine. Is the immediate code indicative of something that would make it less likely to have a positive result from cleaning as opposed to an intermittent code?
Immediate code should make no difference in successful cleaning.
I did get it off without removing for the input shaft. Maybe I'm just dumb but I'm glad i was on flat ground because I went to unscrew the bolt to the input shaft and instead of coming off my car went out of park and moved a few inches. That is about as close to a heart attach I have ever had. E brake and block in front of the front tires later I did jiggle it around then re tightened and no change. I am worried I will not put a new one in properly. How do you know when to tighten the set screw/bolt for the cable?
