misfire
misfire
Gooday all finally getting around to address the disco problem getting misfire 1 and 3 cylanders and a 1300 code has new coils and 8mm wires and plugs pulled the plug getting good spark and it was wet with gas i have new upstream o2 sensors however prior to this happpening i had a rattling cat going to get a compression tester and do a test any use in doing a cooling system pressure check?thanks
Hi everyone well after chasing round all afternoon i was unable to rent or purchase a coolant pressure tester with an adapter that fit i `will do a compression test tomorrow,,,,,just to see where things are,,,,,,thing is with this millage should i maybe just go ahead and tear it down?the truck is off the road and garaged,,,been a good truck this far quick question should i still go ahead and warm it up with the obvious misfiring or do cold thanks
Thank you for your reply i am going to redo the test warm and will post after should i get the necessary fittings to do a coolant system check?want to rule out slipped liner as much as possible before teardown no smoke in exhaust...... or will the condition of the head gasket show a slipped liner?
