miss fire hell out of ideas
Disco 2 99 model was running fine stopped at restraint started back up backed up and it stalled, it fired back up but had no power and a bad miss pulled codes it 304 305 307 changed plugs wires and sea foam no better, still getting 304 305 307 won't idle well and I am at my whites end any ideas would be grateful
Check the boots on the plugs.
They have to be seated properly.
You need to push them down until you feel the metal cap engaging the plug.
You may benefit from just a dab of spark plug silicon on the inside of the boots to help them ease on.
but just a tiny tiny bit.
Check that you put your maf back on OK.
Check the rubber pipe from the MAF to the plenum.
Make sure you put the MAF plug back on the maf properly.
Make sure you have the air box temp plug plugged into the air box temp sensor upstream of the maf.
Post your fault codes.
Use http://enginecodemaster.com to look up rover codes. Enginecode master was made from the landrover service manual.
