brake lights on all the time....switch works
hey guys..
i f-ing cursed today...first my ignition lock and now my brake switch.
-the brake lights are on all the time when the ignition is on
-brakes work fine
-SWITCH DOESNT MAKE CONTACT WITH PEDAL ARM!!!!!
-if i remove the switch and hold the plunger in..the lights go off!!!
i used some duct tape and 4 pennies and added some material between the plunger and the pedal arm.....worked like a charm.....
when the switch brakes...can the plunger stop coming out and cause this issue? the switch feels crisp...i dont get it
-brakes work fine
cosmiccharlie
06-22-2014 12:45 AM
BearCatRover
12-11-2013 04:03 PM
