Mystery oil leak. HELP!
on
Hi all.
I posted on here a little while ago but still trying to find the answer or someone with the same problem.
It an 03 Disco 2 4.6L v8 hunk o ****e. FYI
I have an an oil leak coming from behind the engine mounts on both sides of the engine.
Before you say it, no it's not the rocker covers or valley seal. I de-greased the engine and then ran it. The top is completely dry. But when I crawled underneath there is a steady seep coming from right where the motor mounts are on both sides.
Without removing these here I cannot pinpoint the location. So my question is this.
do the motor mounts bolt through the block lending itself to a potential leaking point? The bloke who had the car before me had them replaced they are brand new.
On the passenger side I found a 10mm square headed sort of grub screw bolt which I wound in (conveniently the same size as a half inch drive)
But no luck.
I don't mind a bit of a leak on a landy but this is too much. People in the car park keep asking me if I'm aware of the leak and to get strait to a garage. Never been to one in me life apart from MOT or smog 😁
Any info appreciated.
also Ive put a picture on of the leak.
But no luck.
on
This
As you mentioned, there are prob a couple of others behind the mount that need attention as well.
https://www.amazon.com/Permatex-82180-Maximum-Resistance-Silicone/dp/B0002UEN1U/ref=sr_1_1?ie=UTF8&qid=1489539286&sr=8-1&keywords=rtv
