Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-19-2012, 06:05 PM
boris_gti's Avatar
Senior Member
Default Need Help Reading ABS Faults
Hello everyone,
3 Amigos have been on steady for 3 weeks now. My scanner just came in and here is the story:
I plugged it in and the "bling" sound came ON (same noise as when 3 Amigos show up). I assumed that now they are reset. But no.....they still stay ON. I did this 3 times and here is the report (see attached image).
Please help me read these codes and what would you do to fix the faults. Like I said...3 Amigos are still frickin' ON!!!!
Please advise and thank you!
Boris
__________________
2003 Discovery SE7
84,000 miles
'98 VW Cabrio-Wolfsburg Edition
'03 Land Rover Discovery-SE7
'09 Mini Cooper "S"-JCW Scheme
'04 Suzuki GSXR1000-Yellow/Carbon fiber
Old 01-19-2012, 08:40 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Looks like you need to rebuild your shuttle valve, there are kits out there to do that.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-19-2012, 09:36 PM
boris_gti's Avatar
Senior Member
Shouldn't I use option B in the write up section on ABS fix?
__________________
2003 Discovery SE7
84,000 miles
Old 01-19-2012, 11:26 PM
lordmorpheus's Avatar
Senior Member
I'm curious how old the wheel speed and ECU faults are, but from the active code of 114, definitely check out the ABS sticky at the top of the page, and check Josh's site for the writeup.
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Old 01-20-2012, 06:56 AM
boris_gti's Avatar
Senior Member
I read Josh's write ups and they are great. I think I should be going with "Option B"? What do you guys think?
__________________
2003 Discovery SE7
84,000 miles
Old 01-20-2012, 07:23 AM
Send a message via Skype™ to Disco Mike
Do both the A and B repairs while you are in there and make sure to replace the 2 o-rings. Do a full 2 quart DOT 4 brake flush when you are done.
Once done, most likely the other codes will go away.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-20-2012, 08:01 AM
jafir's Avatar
Senior Member
Doing A and B makes no sense whatsoever.
Quote:
That told me that I don't need to do OPTION A.... EVER... I don't need to mess with that little SVS circuit board and risk cutting it up. It became clear this method was better.
Hopefully I have won you over on your decision to do option B.... so let's do it!
Do option B, but make sure you test the switch before jumping right into the mod.
__________________
______________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
Old 01-20-2012, 08:51 AM
Lots of things in this world make no sense at all, but you should do it cause both issues do happen at some point in time so do them both at the same time and be done with it.
__________________
Mike
Need Parts?
Old 01-20-2012, 09:03 AM
jafir's Avatar
Senior Member
The instructions even say (which I quoted by the way) that there is no need to do option A, EVER. The repair that is done in A is completely bypassed by the repair done in option B.
__________________
Jafir
2004 Acura TL
Old 01-20-2012, 03:30 PM
boris_gti's Avatar
Senior Member
Thanks guys. I will be going with "Option B". If I remember correctly, there is no brake bleeding required....correct?
__________________
2003 Discovery SE7
84,000 miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
