need a screw for the oil dipstick bracket?
If you are like me, and needed a screw for the oil dip stick bracket. Well look no further. I have found the solution.
I've found that the screws for the clips that hold the spark plug wires to the valve covers works pretty good. If you have a clip that isn't being used. You can take one of the screws out and use it to hold the dipstick in place.
Hope this helps, and this tip has probably been mentioned before...
bcolins
07-27-2013 12:50 PM
rsr50
12-26-2012 04:17 PM
