If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Any ideas on the problem?
Cant wait to find out how much this will cost.
__________________
2001/Disco SE7/105,000 miles
DIY repairs: Valve cover gasket(1/02/12),Plenum gasket(1/02/12), Crank Sensor(1/20/12),Rotors and Pads(1/21/12), Oil Sump Gasket(1/22/12),
Oil Pump, Timing Chain kit, Head Gaskets, New Water Pump, Thermostat, New hoses, New 8mm Wires, Bosch +4 plugs, New Fluids all the way around, mikes 60k mile service complete, Exhaust gaskets (2/1/12 - 2/29/12).
then it's a cheap fix. i bought my evap stuff used from paul grant
So what are these codes telling me? What needs to be fixed?
__________________
