New to me D2 SD
Where are you ordering this red clip from?. Mine is cracked, needs replacing, I've been looking to replace it for awhile now,
Linky from Atl British. Looks like there is more to it than just a clip....
Intake Manifold Brake Servo Vacuum LZN100220
bmeier (01-27-2015)
On the soft brakes that firm up after a couple of pumps, that sounds like air in the system, or (in my case) calipers that are no longer square due to excessive corrosion, or caliper slider pins that are sticky/ seized.
If you're confident that you've bled all the air and old fluid from your system, your next step is to carefully look at your calipers.
congrats on the D2. I've converted over to speed bleeders for the brakes, makes the solo job that much easier. x2 gazillion on the UltraGauge or comparable- the stock gauges register "warm" only after you've overheated. x2 on the front prop shaft. also- check the 90k service and get crackin' on that one.
On the Ultragauge, is the EM Plus worth it? Mainly, will I be using the additional functions, or is the standard v1.2 fine?
Kind of like my iPhone, I don't use half the functions on it....and I hate that.
I work as a service manager at a indie German repair facility, and we have Aultel, so general code reading, etc I can handle there. Just want the UG for monitoring while on the go....it's cheaper than buying and installing analog gauges.
So, in my quest to get everything working that wasn't when I got the truck (the window washers was the only thing), I broke one of the studs off the spare tire carrier. One was already broken. The third fought me every tread.
Ended up disconnecting the washer hose at the pump and giving it a nice blast of compressed air. Fixed.
The front washer hose was broken at the 90 degree that's integrated into the hood pad clip. I simply bypassed that with a vacuum fitting and all's well.
Now, get a new spare carrier, or weld in some new studs...
Also, tips to get the tail door panel off? I was trying but stopped. Didn't want to tear it.
Tried that panel tool. The panel, being recessed in the door, made me think I was bending and deforming it too much. I'm going to order some (all) of the clips. I wanna get back there to install this ladder that came with the truck.
I'll probably just blast out the old studs with the plasma cutter and weld in new ones. I don't plan on going over 32" tires. I kinda like this thing as is. My RRC is pretty terrible to drive with the 33"s etc.
