New Starter and still NOTHING?!?
My 2001 DII SE 4.0 v8-- was running fine. Drove to work ( aprox. 2 miles) no problem; 4 hrs later drove home for lunch 20 min later it would not start. Lights and radio work but no cranking at all not even a click on the first attempt. Subsequent attempts have resulted in a single click and sometimes no click.
I have tried all of the following suggestions and none of which altered the symptoms in any way:
1) locking unlocking innumerable times with every variation of key and fob combinations
2) 1515 reset sequence although the horn never beeped so not sure that actually triggered anything. No Car specific EKA code available. SIDE NOTE: the buttons on my key fob broke off a few months ago but the fob seems to be working fine. I just use my thumb nail to reach the tiny buttons on the circuit board inside.
3) Jumping the battery with another suv
4) Tapping the starter
5) Starting the car in neutral as well as changing the gears several times
6) Replaced the starter
Recent (in the last year) work history includes:
1) Replaced Engine + heater core (resulted in 3 Amigos)
2) Replaced Battery
3) Replaced negative terminal (positive was replaced years ago)
4) Replaced Alternator & Serpentine Belt
Any thoughts on my next step?
2) Replaced Battery
Check the connections at the battery and all the large cable connections.
I once changed a starter only to find it was a semi loose connection on the battery terminal.
Then, had a starter go out on my P38, tried to jump it and still nothing. Had the new starter and tools ready, and thought what the hell. Changed out the battery and it fired right up.
Another place to check, would be the switch on the shifter. The starter inhibitor switch, Is right under the gear selector lever. When in park or neutral, the green wire with the brown stripe should be hot. The other thing is the inertia switch, although i think it only controls the fuel.
I am having the same problem now
I drove it to the grocery store, shopped, came back, and dadaaa. It doesnt work. headlights-domelights-stereo vs everything works but engine doesnt even turn. there is a weird clicking noise once i turn the key, coming from passenger side floor.
starter was good, it was working fine every time i start the car, i dont know if it fails all of a sudden like this.
can any one help my to locate the problem? thanks.
