Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-27-2012, 04:45 PM
Junior Member
Default no air coming from vents hot or cold
I do not have air coming from any of my vents. There is no sound coming from the blower when I turn the heat on.
2001 Discovery II
109,500 miles
Brandon
Old 01-27-2012, 07:29 PM
Senior Member
So in fact you have no blower fan making the noise or moving the air. This is an expensive part, but perhaps we can find some things to check.
The RAVE electrical manual shows that Fuse 7 would be good to check. The power goes thru a relay, which has connector C153 on it, pix attached. The relay puts 12 volts to fan, but then fan is switched by another relay with connector C901, and the power transistor at C858 varys the speed of the fan. They all have to work for fan to behave.
__________________
Old 01-27-2012, 10:48 PM
Junior Member
Thank you, I checked the fuse already but none of the other things you mentioned. I will check them out.
Tags
air, c858, car, coming, dscovery, hot, land, part, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
