Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Search
Old 12-02-2010, 01:50 AM
Junior Member
Unhappy No heat
there is no waterfall sound or gurgle . the upper and lower heatercore hoses get hot leading me to think that coolant is flowing through the heatercore . when i turn on high heat all i get is cold air . i looked in the manual and saw that there is a separate heater / ac fan with two separate fuses . will check the fuse in the morning to make sure its not blown . but has anyone everheard of the heater fan motor going bad. had system flushed twice so i dont believe that there is an air bubble in the system .the temp is fine.gotta get this fixed becouse its gettin cold. 2000 disco 2 with 115000 .
Old 12-02-2010, 08:19 AM
Send a message via Skype™ to Disco Mike
So, where is your coolant level when the engine is stone cold, have you been having to add coolant?
There are no fuses to make the heater blow hot, you have air in the system, do you know how to bleed the system.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 12-02-2010, 06:23 PM
lordmorpheus's Avatar
Senior Member
If the coolant is full, and a proper system bleed has been done, I would check the blend door motor under the dash that controls a flap, determining whether air blows through the heater core, or the A/C evaporator.
RAVE can help you find this: http://www.landroverresource.com/
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Old 12-03-2010, 04:12 PM
Member
I have the same problem. Last time I bled the system, it took almost 15 minutes for it to blow heat, and even then it was not hot. Shortly after, I drove to the store, and no heat at all, only cold air.
I do hear a small motor/gear turning sound behind the AC/HT controls, mostly when i stop.
99 DII 160K
Water Pump Replaced '10
Throttle Body Replaced '10
Thermostat & Rad Hoses '09
Old 12-03-2010, 08:53 PM
Senior Member
Is the gear/motor sound continuous? If so, it sounds like a stripped actuator motor mechanism.
__________________
Old 12-06-2010, 08:40 AM
Member
It's a muffled sound, not continuous. The same sound when toggling between 'circulated' air.
Is there a reason it would blow heat immediatly when bled, but not afterwards ?
Also how would I check the blend door motor ? major disassemble ?
I'll try bleeding again, i have read that sometimes it takes multiple bleeding to get all the air out.
Old 12-06-2010, 08:50 AM
Sure, you may be loosing coolant, do a coolant pressure test to verify and repair.
__________________
Mike
Need Parts?
Old 12-09-2010, 09:51 AM
Member
Pressure test revealed Throttle Body heater hose is leaking just beneath the plate where the hose connects. I should have replaced the hoses when i replaced the plate.
Coolant was leaking and running down the valve cover and dripping on plug wire "5"
That explains my heat issue and recent Cyl 5 misfire code.
Will update after hose is replaced.
Thanks
Tags
ac, discovery, heat, heater, ii, land, no, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
Emails Backup
