Ok dumb question.........
Old 10-29-2011, 08:28 AM
kman35ca's Avatar
Default Ok dumb question.........
Changing the tranny oil this weekend, and the diff oil, transfer case and plugs.
1- Where the hell is the tranny dipstick and filler?
2- Anyone know if I run 140-80 gear oil in the diff and transfer case, is that going to be a problem when it hits -30 40 this winter?
Old 10-29-2011, 08:32 AM
This could be a long reply, send me your number and I'll call you this morning.
Old 10-29-2011, 09:42 AM
dgi 07's Avatar
And he said let there be a write up.
https://landroverforums.com/forum/di...uid-dii-23070/
and it was good.
There is no dipstick or filler tube on your transmission sir.
As far as question two goes, she may feel a little down on power until the diff's heat up causing you to put more strain on your tranny, transfer case, diff, etc. So theoretically, over time, yea you could be doing a little more harm than good. Theoretically. imho, put what stock calls for.
Old 10-29-2011, 09:51 AM
NiteTrain's Avatar
wouldn't be a problem for my rover..cause it would be heading south with me in it
btw, no dipstick..you have to pump fluid into transmission pan
Old 10-29-2011, 06:12 PM
Use 80w-90 gear lube if it gets that cold, you may blow a diff if you dont.
armlock
12-29-2007 07:20 PM
S1disoinSC
10-29-2006 01:08 PM
willb285
10-02-2006 02:33 AM
kend500
05-19-2006 12:28 PM
FORDSTANGER
06-07-2005 06:02 PM
Quick Reply: Ok dumb question.........
