No Speedo or Odom after Aux. Light Switch Install -> Plus HD, TC, ABS, & Brake Light on
Old 11-07-2006, 12:40 AM
angasreid's Avatar
Default No Speedo or Odom after Aux. Light Switch Install -> Plus HD, TC, ABS, & Brake Light on
2004 Disco 2
Hello all,
I just installed the Rover accessory the Driving Lamp Kit with the stock switch and all went well. I hooked the battery cables back up, like it said in the directions, and the lights worked.
Then I looked at the dash and saw the Trio (HD, ABS, & TC) Lights were all on, plus the light that says "Brake". I've been having issues with the Trio lights before, and the dealer is actually replacing my wheel speed sensor.
Then I went to drive the car, and no speedometer and no odometer. Could this all be from the wheel speed sensor?
Curious what you guys think,
Angas
Old 11-07-2006, 10:36 PM
angasreid's Avatar
Default RE: No Speedo or Odom after Aux. Light Switch Install -> Plus HD, TC, ABS, & Brake Light on
Just got my Disco back and the diagnosis was a "Loose Connector at the SLABS ECU (Self Leveling and ABS). Apparently the Shuttle Valve was replaced as well. So I hope this fixes my ordeal. Made it back from the dealer with no problems either.
Thought I would share with you guys what the problem was.
-Angas
Old 11-08-2006, 01:02 AM
Brad S1's Avatar
Mine just did the same thing on a driving light install, I apparently pulled a wire too hard and pulled the harness of the cluster, super easy fix... I just pulled the gauge cluster back and saw the harness wasn't fully plugged in, plugged it back in and it works fine now.
Old 11-08-2006, 02:46 AM
angasreid's Avatar
Did you get all the same lights I did on my dash? Just curious
Old 11-16-2006, 02:13 AM
rastaman's Avatar
4wd High
So did you ever get the trio lights fix?me and some other guys are having this same problem now.Any help will be appreciated.Thanks
Old 11-16-2006, 11:40 AM
Angas,
Are you staying out of trouble lately???
Mike
Snafu / Disco Fries
04-13-2011 05:40 PM
RjBu
10-14-2009 10:41 AM
kman3786
05-04-2009 09:21 PM
aussiedg87
03-05-2009 11:26 AM
salve7
09-12-2008 03:34 PM
Quick Reply: No Speedo or Odom after Aux. Light Switch Install -> Plus HD, TC, ABS, & Brake Light on
