Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-30-2012, 07:36 AM
Member
Default O1 disco won't blow hot air
I was making my hourly commute this morning when I noticed about midway that my truck was no longer blowing hot air, but cooler air. It seemd to be acting like a hot water tank where I had to keep turning the temp up higher and higher in order to get any heat to come out. By then end I had the heat set at 82 and it was lowly reverting to cold air. I am not a wrench at all, and I am an hour away from home, I am can deal with a cold ride but just want to make sure I'm not ignoring a much larger problem. All my gauges are reading fine, no lights on. I do have to add antifreeze every so often as I must have a leak, but I just recently topped it off.
Advice?
Old 01-30-2012, 08:23 AM
drowssap's Avatar
Senior Member
you have a leak which has know turn into an air pocket it sound. You need to fill your system, purge it of all air. and then preausure test the cooling system to locate your leak. And yes to are doing damage driving it that way, i would stop driving it until you have done the above and located and repaired your leak.You are losing heat because there is not enough coolant in the system to make heat,then there is not enough coolant in the sytem to cool then engine. Also if there is not enought coolant in the system then the guage can not read the tempurture.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 01-30-2012, 08:52 AM
Member
Thanks,
I am in Boston, I have an hour ride home. I wouldn't feel comfortable just going to any mechanic this way. Is an hour ride disastrous?
Old 01-30-2012, 09:54 AM
MoShadeTree's Avatar
Member
I would add coolant to the system while it is cold. Check for any visible leaks while the truck is running to ensure that it's a small leak (dripping) and not a pin-hole (squirting) althought both can turn bad quickly. If you can't see anything leaking or it's a small leak you may be able to make it home safely. If you see a leak that's faster than a drip, I would take it to a shop vs driving an hour. I would hate to see a $100 hose repair turn into a $4,000 engine replacement.
__________________
2004 Chevy Suburban (Green Monster)
2001 Nissan Maxima (White Shadow)
2001 Land Rover Discovery (Midnight)
1994 Land Rover Discovery (Green Thing)
*** Ain't No Party Like A Disco Party ***
Old 01-30-2012, 10:25 AM
drowssap's Avatar
Senior Member
while its cold open the bleed screw and fill it the best you can. where in boston are you and which way are you heading.
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
Old 01-30-2012, 10:42 AM
Senior Member
You have lost enough coolant to be below the level to even keep the heater core full. The thermostat is in the steam room at the top, but that steam is nothing like the hot water that is somewhere in the engine trying to carry the load for the missing 1 gallon or more. One guy had to put in two gallons. In a 13 quart system. Even if you don't have coolant you can use bottled water in an emergency, don't leave it parked outside with just water. May have to pull off and add some on the way home as well.
__________________
Old 01-30-2012, 10:44 AM
drowssap's Avatar
Senior Member
there is a place Rover of Boston or Boston Rover they are located on A street in South Boston.
He is an indepedent shop and has been there for at least 20 years that I know of.
I had him look at a problem with my truck, unfortunatley he could not help me with my wiring problem, but he did not charge me for the 2-days he worked on it either.
So that alone says a lot about the guy to me, he could have handed me a bill for $800-$900 for dianostic testing like i'm sure the dealer would have and i would have paid it.
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
Old 01-31-2012, 02:24 PM
Member
Took it to my mechanic apparently I have a leaking front water gasket says labor is a lot to get in there and parts are around 100$. Says total will be 650ish....
Not happy...
Old 01-31-2012, 03:32 PM
Send a message via Skype™ to Disco Mike
Be more specific, what exactly is leaking?
Have you already up-graded your upper radiator hose to the new style with the bleed screw mounted on a tee instead of molded into the hose, if not, that should be changed along with a new t/stat and flush the Dexcool coolant out of the system switching to one of the better green coolants like Peak.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-31-2012, 04:38 PM
Junior Member
I also live in Boston. My mechanic has a shop in Saugus right next to the Square 1 mall. He is very reasonable.
Tags
02, air, blow, hot, land, rover, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
