Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-18-2012, 08:39 PM
Senior Member
Default O2 codes after head job
I just did a complete head job on my D2 because one of the heads was leaking and while they were off I decided to do them right.
I was getting O2 codes prior to this (I posted a number of times before while trying to figure this out).
Now that I have the motor put back together, I'm getting
0134
0135
0154
0155
I had another set of sensors so I put in the bank 1 & 2 sensor 1 to see if that changed and it didn't.
any sugggestions on what these could be or would they possible take a while to go away...I have not driven the car yet, only idled it.
Thanks,
Steve
__________________
2003 Land Rover Discovery HSE
Old 01-18-2012, 08:48 PM
Senior Member
Wiring or connector problems - these are codes for continuity problems. See attached pages from Bosch manual on the ECU codes and what voltage values trigger them
__________________
Old 01-18-2012, 09:00 PM
Senior Member
Thanks! i'm def saving that. Any suggestions on remedies?
__________________
Old 01-18-2012, 09:51 PM
bosshogt's Avatar
Senior Member
Check your front two O2 connectors for green corrosion. Clean them with electric spray and use dielectric grease. Took the dealer over a month to figure that one our on my 2003 2 years ago.
__________________
2003 Discovery HSE Magnecore, DBA Slotted Rotors, LR Ladder, G4 Lamp Guards, Headlight Guards, RN Hood Blackout, MagnaFlow CatBack, ScanGuageII, Optima Red Top, LR 16" Typhoon Black Rims, Goodyear DuraTracs, OME 2" Lift, Frt Botorff Bumper, Skid plate, Rear Bumper by Dave, HLC tire carrier.
Tags
2003, code, discovery, o2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
