o2 Sensor Circuit Bank 2 Sensor 1
You'll want two if these
Bosch 15175 Oxygen Sensor, OE Type Fitment https://www.amazon.com/dp/B0018R5SOW/ref=cm_sw_r_awd_iRLTvbDZ029NX
And two of these
Bosch 15630 Oxygen Sensor, OE Type Fitment https://www.amazon.com/dp/B000VASG5K/ref=cm_sw_r_awd_eSLTvb1KN6P2M
Always replace O2 sensors in pairs. Expensive, but worth it.
And two of these
Yep. Alex_M gave good advice. he is da man.
you can also try my lookup table for codes
http://enginecodemaster.com
just a PHP lookup table really.
I never understood the logic in replacing the downstream sensors when upstream sensors are replaced. If one upstream sensor fails, sure, replace the other upstream, but why bother with the downstream? The only thing they do is monitor the converter. The have absolutely nothing to do with fuel management. I replaced both upstream at 100k not because they were bad, but because I figured they were switching slower than new. Downstreams are still original at 150k. If I get a code for one, I will replace it then.
RSDEVIL (12-29-2015)
