Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-02-2012, 07:49 PM
MrFlea1's Avatar
Member
Default OIl Filter Purolator L40316 Question
Are these filters really suitable for the 4.0 Discovery 2. I have a 2001 and see they are available at Advanced auto parts BUT it says not for 2001 discovery, and how much more oil should be added to the oil change to compensate forthe bigger filter??
Old 02-02-2012, 08:42 PM
Send a message via Skype™ to Disco Mike
Usually right at 6 quarts. That filter should work, there are better quality filters out there if you want to pamper your engine, like the K&N 3001, Mobil1-310 for the Napa Gold.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 02-02-2012, 09:14 PM
Philip Lawrence
Send a message via Skype™ to Spike555
That filter is fine, figure on a extra quart of oil, fill the filter with oil before putting it on the truck.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 02-02-2012, 09:52 PM
MrFlea1's Avatar
Member
OK looking on the MANN site there are two filters that go by the same # L40316.....The MANN # is different but the puralator # is the same
Mann #W950-4 has a Bypass Valve Pressure of 2.5 Bars and the W950-7 has a bypass pressure opening of 0.7 bar What is the difference and which is better. I see alot of dicussion about pressure difference on here But can you explain to me what the difference is and which would be better? Thanks
Old 02-02-2012, 10:19 PM
Senior Member
The W950/7 is also a Purolator L40107 per a phone call I made to Purolator tech support. The bypass pressure rating is the pressure that must exist across the filter for it to go into bypass mode and sends just unfiltered oil to engine. It does not turn off the flow of oil. If filter was very dirty, it could go into bypass. But when oil is really cold filter could go into bypass as cold oil is harder to push through. This is offset by the increased size of the filter media IMHO. I have a Purolator L40316 on my truck at this point. 44 PSI cold idle or 2500 rpm. 42 PSI hot 2500, 24 PSI hot 700 rpm. I believe I'll try the L40107 next time. RoverMasterTech got hot PSI readings at 2500 rpm in the 60+ PSI range on a D2.
__________________
Old 02-03-2012, 09:53 AM
MrFlea1's Avatar
Member
I understand higher oil pressure is good ....BUT should you be concerned that maybe being so high could cause an unwanted oil leak somewhere? Oh by the way I am going to run some Rotella 5w40 with a K&L filter on my D2...then switch filters during the next oil change. Going to research the "Larger" canister to see if "Bigger is Better". OPinion!!
Old 02-03-2012, 10:10 AM
Senior Member
The larger filter provides extra oil capacity, which is good. Compared to some filters, it will provide a pressure boost, depending on your oil pump. It won't makes any more leaks than you already have, not that big a change. It does filter under 20 microns, which is the cut off point that a number of engineers consider, particle below that size are not much of an issue. A human hair is like 60 microns in diameter, so we are talking small.
__________________
Old 02-03-2012, 11:16 AM
drowssap's Avatar
Senior Member
the more filter matter you have in the filter the more it can catch, undoughtedly . but the Mann #W950-4 has a Bypass Valve Pressure of 2.5 Bars is just to high, the Mann #w950-7 would be closer to the stock rover filter.
You can have to much oil preasure which is the different between a high preasure oil pump and a high volume oil pump, you never want to run a high preasure you want high volume.
Thw Mann is a nice big filter but like DM said there are better filters not as large but they trap smaller particales.
jmho
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 02-03-2012, 12:34 PM
antichrist's Avatar
Senior Member
A higher surface area is going to result in a lower PSI at the media, at a given pump flow & PSI. Once the oil is warmed up and the filter is pressurized it's not going to matter, but with cold oil trying to get pushed through the filter by the pump, there is going to be less PSI so with a high bypass pressure you're going to have reduced oil flow for a longer period of time.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 02-03-2012, 01:27 PM
MrFlea1's Avatar
Member
Just came back from Advanced Auto. They are starting to stock and sell MANN filters. They dont have either the 950-4 or the 950-7 yet > I did order a Purolator L 40316 ....the other L 40107 isn't available at my local place ...he can't even order it so I may go to The Mann site and order a few.
Tags
80, club, discovery, filter, l40316, land, oil, purlator, purolator, range, reviews, rover, sport, w9504, w9507
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
