Don't need to remove cluster to check bulbs,, they should light-up when you turn ignition key to start position & then go off when car starts,, if it does that then bulbs are ok,
If lights don't come on at all then you have a problem,!!
Get the flywheel inspection plugs from the dealer.. I want to say they are $13 a piece.. No sense trying to source a used one, as they will not go back in after they swell with time and oil.
