Is this original front drive shaft?
#31
So I crawled underneath yesterday to try and get the old one off, but the bolts and nuts are pretty hard to get to with my standard socket. The front set is installed with the bolt on the rear/shaft side and nut in front. two questions:
1. Am I relegated to using a side wrench? If so, when tightening up after installation of new shaft, how is 35 lbs of torque assured?
2. How do I get to all 4 bolts/nuts when some are "hidden" out of sight while under the vehicle? At least one on each end is nearest the underside of the cabin.
#32
#34
#35
#36
From a garagejournal thread "any lock nut with a nylon insert will be grade 2 only as the metal cannot be any stronger or the crimping process for the nylon insert cannot be done. All of the higher strength lock nuts will be all metal with a distorted top."
What's funny is the guy who posted that included a link where you can easily find grade 5 and 8 nylocks.
#37
some people just know everything....
#38
After doing some more research. From Aztech lock nut... Nut grades are letters and classes are numbers..
What is the grade or class of the mating bolt?
The mating part grade or class should be equivalent to the locknut grade or class as indicated in the following table.
Nut Grade Bolt Grade Nut Class Bolt Class
A 2 8 8.8
B 5 9 9.8
C 8 10 10.9
SAE J995: Mechanical and Material Requirements for Steel Nuts (Grade 2, 5 & 8). defines yield, tensile strength and hardness for each grade. Not sure it this standard addresses lock nuts.
IFI-100/107: Prevailing-Torque Type Steel Hex and Hex Flange Nuts Regular and Light Hex Series (grade letters (A, B, etc)
ASME B18-6.6: Prevailing Torque Locknuts (Inch Series) = N2, N5, N8 (for nylon lock nuts). Defines chemical composition and hardness of steel
A 2 8 8.8
B 5 9 9.8
C 8 10 10.9
#39
DiscoJon
07-14-2019 01:51 PM
bballjames
11-13-2012 12:58 PM
TripleThreat
04-12-2011 08:58 AM
