P0171, p0174
#22
#23
#24
#25
I have a question about the secondary air inlet (upper intake manifold), does this need to be block if there is no secondary air installed? Mine has a piece of broken rubber on in, like there was once something installed but there is definitely nothing installed now, would this cause the lean codes?
#26
I Have a Disco 2 V8 Auto that is bringing up P0171 and P0174, smoke tested and all seems to be fine, MAF values look okay, Long Fuel Trim is stuck on +%25, it never moves. What I did notice is that before putting the vehicle in Idle the LFT is already in 25% (both banks). Any Ideas? or is this suppose to be?
#27
Check your SAI solonoid isn't on the fritz.
http://www.roverparts.com/Parts/YDJ100000G
Mine wasn't activating properly and throwing those codes. You can apply 12v directly to it, you should get a very positive, clean click.
DYON83 (04-20-2016)
#28
Thats interesting, there is no SAI installed, although I wonder if there was one as there was a piece of pipe broken of on the Plenum (where the SAI should feed the air intake) before I capped it as I thought that could have contributed to a Vacuum leak. How do I know if there was SAI installed previously (I have only had the Disco for a year)?
#29
The pipes on the intake, facing the engine from the front, are vacuum lines (you can cap the one toward the back, left). . On the right you have cooling lines (front. You can also cap), purse and idle air (behind throttle body and top of intake, on the back).
#30
Sorry Charlie_V don't know why I said Plenum, but you are correct the Upper air intake. Basically you are saying though that it shouldn't matter if the Disco had a SAI and is now removed. There is nothing else that is needed to be done? The thing is with these codes, I don't get any running problems except response, power and Consumption.
