Parking Brake Problem, etc
I apologize in advance for bringing this issue back to light. I have searched the forum and I have read anything associated with the parking brake.
Here's my problem. It seems to be a combined problem of several other posts.
Right rear brake has been dragging and Sunday evening it was very, very hot.(read a post about that) Parked the Landy. I went to move it yesterday evening and she would not move at all. The parking brake had been engaged and when released the cable would not slide.(read a post about that) After inspection. the cables coating has come off and when the Rover is running the cable will spark when the lever is moved. (read a post about that) I have the rave and have read about adjustment of the cable. My problem is I just cant find an illustration of where the cable enters the drum.
Is this a repair I should attempt or should I have someone drag her off for a repair? It seems as if I have a two fold problem. The brakes may need a good bleeding and the parking brake cable needs replacement and probably the shoes as well.
I thought the leaking sunroofs were my big problem until yesterday.
Thanks in advance.
Greg
Thanks in advance.
Greg
bcolins
03-08-2015 07:14 AM
achapman
06-25-2013 03:40 PM
06Range
05-08-2013 09:01 PM
tibyABv6
12-18-2012 10:09 PM
