Replaced ATF and filter but can only get about 6 quarts in???
Old 10-20-2012, 01:33 PM
me 2's Avatar
Default Replaced ATF and filter but can only get about 6 quarts in???
Just changed my fluid and filter on the 02 and could only get barely 6 quarts in. I was told it held 10 quarts, is this correct?
Old 10-20-2012, 01:36 PM
Holds close to 12 but you can only drain out just under 6 quarts.
How dirty was the fluid, if brown and a burned smell, do one more drain and refill to get out as much as possible.
Old 10-20-2012, 01:58 PM
me 2's Avatar
Default stuff
K, thanx mike
Old 10-20-2012, 02:33 PM
ghengis86's Avatar
Torque converter holds what you can't drain , FYI
Old 10-22-2012, 07:54 AM
me 2's Avatar
Default stuff
So Im back to square 1 again with this kick back im getting with the tranny. I can only assume that it IS in fact the torque converter not refilling itself of fluid.
QuakerJ
04-21-2014 07:41 AM
grandkodiak
07-02-2011 07:25 AM
2000 DII
10-23-2009 10:25 AM
awsherwo
04-28-2006 01:28 PM
doeboy
09-10-2005 08:07 PM
Quick Reply: Replaced ATF and filter but can only get about 6 quarts in???
