Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Search
Old 02-25-2009, 03:22 PM
Member
Default passenger side window will not go down
disco II 2001....passager side window will not go down...took the door panel off and look at the regulator and motor all is well except for cracked roller...does anyone know where to get a roller???? dealer told me I have to buy the whole regulator... been looking all over town no luck. please if anyone has any idea.....
Old 02-25-2009, 04:01 PM
jycsalas's Avatar
You don't need the entire regulator. You need to either buy this
http://www.jewellamberoil.com/sales/...roducts_id=185
or do what i did,
http://picasaweb.google.com/jycsalas...torFixerUpper#
or make your own little roller... =)
Good luck!
__________________
~Josh
2003 Discovery S (71K miles)
www.landroverclubvi.com
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards,4 new ball joints, 265/75/16 Discoverer S/T, In-line thermostat.
Coming soon: Install Greg Davis rear bumper, 2inch Lift
For the future: .... wait and see....
Amigos Free since 11/09
Old 02-25-2009, 06:02 PM
okdiscoguy's Avatar
Senior Member
I took some 2 part plastic epoxy and glued mine back together, holding it with vice grips and spinning every 30 seconds so it didn't stick to the shaft. Then I took a file and evened it out, and it has worked fine for almost 3 years now.....
__________________
RAVE
Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
Old 02-25-2009, 06:22 PM
jycsalas's Avatar
3 years?!! thats sweet!.. i don't know why i didnt think of that... Maybe cuz I was missing some chunks of the plastic wheel... i don't remember. =)
__________________
~Josh
Old 02-25-2009, 06:36 PM
okdiscoguy's Avatar
Senior Member
I was missing chuncks too, and it was oval shaped, but putting extra epoxy on it allowed me to file it back down. I actually had to do it twice because I used jb weld the first time. Didn't work. You have to get the light colored stuff for plastic that stinks really bad. The more it stinks, the better it sticks. That's been my rule of thumb anyways...
__________________
RAVE
Good Oil
Old 02-26-2009, 10:10 AM
Member
Default window regulator roller
I just went ahead and ordered the metal one from falconworks.com ($40) seems steep considering an aftermarket is only $80....I only did that instead of making one....due to the girlfriend smokes and like to use the window alot and kids slamming the door all the time. I live in southflorida and it gets hot. My roller is cracked and a piece is missing. I could glue and fill but i am afraid the heat would get it eventually. I could file one down (drawer roller, another car) but I just dont want to be messing with it since I dont know what i am doing. I will repost with the outcome so eveyone will know if the part works well. thanks for the tip jycsalas
Old 02-26-2009, 10:20 AM
AK Rover's Avatar
Senior Member
Send a message via MSN to AK Rover
I recently replaced my passenger side regulator. I kept the original regulator planning to rebuild it with the metal rollers as soon as I get back to work. Next time I have a regulator fail I am going to install the metal rollers and be done.
__________________
To download the RAVE manual, follow this link http://www.landroverresource.com/
Old 10-21-2012, 02:00 PM
Junior Member
Default Regulator Rollers
I can replace the rollers on the whole regulator for half the price of the new one. You can email me for a quote the regulator has to be removed and shipped to me though.
Old 10-21-2012, 06:33 PM
Here's another option $10 window regulator fix
__________________
Free download of RAVE and Rover shop & owner manuals (LR3 and older) in pdf: http://landroverforums.com/forum/gen...ing-lr3-57978/
Workshop/electrical/owners/overhaul/ECU for Discovery, Range Rover, Freelander, LR3, and older models
Cooling System Problems: http://landroverforums.com/forum/gen...verview-51034/
Tags
back, disco, discovery, doesnt, land, landrove, regulator, roll, roller, rover, se, window, windows, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
Emails Backup
