Pinion gear shimming
I have 02 disco with play on my front axle pinion gear. Its not the drive shaft. Ive rebuilt it twice over past 10 years I've owned it. Its too much lash on the pinion gear. Ive rebuilt axles before on different brand cars. I have experience. My question is does anyone know what the pinion gear shim size is roughly? I have found Atlantic British sells them but different sizes. I don't want to buy all of them if theres a standard size that is used and I can reference that to buy a thicker shim. Or maybe someone can point me to a retailer that sells a shim pack for pinions on rovers. I dont have a ton of play but I'm getting tired of hearing a clunk when I let off the gas and then go again.
Try these guys: Coil Sprung Differentials Overview Regarding shims, they are selected based on the clearance. There is no standard shim size. You will need to pull your yoke and measure what you have.
Google Ashcroft Transmissions and watch their video which is informative.
I've rebuilt and set up a ton (literally) of GM rear ends. Can do in my sleep. The rover is like a Ford 9". Only did 1 of those. Took most of the day and some cursing. Can do a GM axle in a couple of hours. With them you can shift the carrier unit left or right to tighten or loosen the gear mesh. Just set up the pinion gear with a general size (GM is .035) shim and shift carrier to obtain proper mesh. The rover is different and was hoping someone could chime in with a quick fix. I've gone through the rave manual and was just hoping for a miracle answer but being a rover........NOPE! Thanks. Think I'm gonna buy a rebuilt unit and swap out.
