Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-19-2012, 02:15 PM
NoBama316's Avatar
Junior Member
Default Power Steering pump gasket
Anyone know a source to buy a gasket other than making one?
Thanks
Old 01-19-2012, 04:42 PM
94svt50's Avatar
Senior Member
mine was leaking profusely so I fixed mine with JB weld. Just take it apart and clean everything up really well, use brake cleaner or some other evaporative cleaner. Then butter up both parts of the pump with jb weld and reassemble, just tighten up the bolts finger tight. Bring it inside to get it warm and let it sit for 24 hrs then just torque the bolts down and re install. Im at about 300 miles since repair and no leaks yet.
__________________
'03 HSE7 112k driveshaft/headgasket/water pump/oil pump/all fluids akebone pads and new rotors and I have almost had it a year
'02 pathfinder 160k
'89 yota 4x4 251k
Tags
discovery, dismantle, gasket, gaskets, land, landrover, power, pump, rover, steerimg, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
