Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-22-2012, 11:37 AM
Senior Member
Default Power steering Pump replacement
I am replacing the power steering pump, suction hose, reservoir and all the O-Rings tomorrow. I have 2 quarts of original land rover power steering fluid.
I have some questions:
1. I have cheap preston fluid in there now, obviously most is going to come out but some will stay in the steering gear, that fluid getting mixed with the new fluid, could that cause problems?
2. When filling the reservoir, will fluid go into the new hose attached to the pump or is there going to be a big air pocket getting sucked into the pump and can this cause damage to the pump
3. Will bleeding take care of the old fluid and also air, at the same time I don't want to over due it, since I have only 2 quarts of fluid
4. The new/old reservoid that I bought has some dirt in the filter, and I don't know how to clean it. Can some water throug the suction hose inlet cause any problems?
Thanks
Old 01-22-2012, 08:14 PM
Senior Member
There is a bleed screw on top of the steering box, release it and keep adding fluid until bubbles stop. Pan below of course. If yukky fluid is coming out keep going until output = input color. You may be able to get feed hose to pump attached to reservoir, then pour in some fluid before attaching feed line to pump, to fill the feed line, minimizes any bubble.
__________________
Old 01-23-2012, 03:48 AM
Junior Member
Default power steering
hi , i have a year 2000 discovery can some one help ...
i found the break fluid containar, but their is another container that has two resevors in-side it split like 40/60 one had a simi white fluid and the other one was empty it seems it had a red color fluid is that correct and what are they for ? one could be power steering and the other ????
can any one correct me or answer me Thanks
Old 01-23-2012, 05:11 AM
Member
I have the same non-ACE bottle as you.
ACE-fitted models uses a double connection bottle. If you don't have ACE the container has the same shape but only one tube connection set.
I just wonder why there is a baffle inside on non-ACE models.
Old 01-24-2012, 09:24 AM
Member
After you get the pump on and before you put the belt back on, you could probably prime it by hand. Add fluid and turn the pump and that should fill the pump with fluid if you are worried about damaging the pump on start up.
Tags
2000, change, changing, clicking, discovery, gm, hose, land, power, powering, pump, range, rover, steering, suction, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
