Puzzled by my steering
I think I'm going to have to break down and take her into a (gasp) - mechanic.
But thought I'd see if anyone here has any ideas:
There's something not right about my steering. Hard to put my finger on, but feels like there's sort of hills and valleys to the resistance when turning.
I had her up and both wheels off today. The only noticeable thing is that when it's 98% to the right there's a sort of clunk that seems to resonate through the whole system. I can move it back and forth through the clunk with a 2º arc of the wheel. And that's the only spot where I get any play when moving the wheels by hand.
All the components seem good, I can't get any play from anything else.
I'm thinking it's the actual steering box. I really don't want it to be, but I think it is.
Side question: when I spin the front wheels by hand when it's running (in park) as soon as I get a little bit of speed up (like 3rpm) there's a noise from the heart of the beast that I can't imagine what is. Sounds like power steering engaging (don't think it is just sounds like it) or a little like the hill descent noise. I feel like there's a slight increase in resistance when it happens.
That's really just curiosity, I have no reason to believe it's not normal.
As usual, thanks!
As usual, thanks!
Sounds like the box might be worn out, unfortunately. Did you check all the suspension and steering parts for play? I would probably check that before making a call on the box.
Is the noise you hear when turning one wheel the traction control coming on? Turning one wheel would give it a speed reading that doesn't match the other four wheels.
Good one, far less hassle and far cheaper than the PAS box but still check the float adjustment in the PAS box which makes all the difference to steering. Screw the screw down gently until solid resistance is felt then back it of 1/8th of a turn and make sure the screw doesn't move by using a screwdriver when tightening the locknut.
jycsalas
04-17-2009 02:21 AM
Evian
08-18-2005 11:34 PM
