Reading the engine oil dipstick
I was checking my engine oil yesterday and it was on the lower end of the fill mark. So I started adding oil and it took more than I had thought it would, but finally got it to full.
Last night I was noticing alot of smoke coming out of the exhaust, I figured I must of overfilled by a little bit.
When I checked the dipstick again, I was past the full mark by a couple of inches. I checked it a couple of times and same thing happened.
I spun the dipstick 180 degrees and put it back in, checked again and now it was on the full mark.
I noticed that the oil is at different levels on the dipstick, depending which side of the stick you are looking at.
When the oil is on the full mark facing you, the oil is a couple of inches higher on the other side of the stick.
Is it just me or is this normal?
Always check the oil parked on level ground and after sitting overnight.
My dipstick only have writing on one side and that is the side I use and because I have some sort of OCD I always put the dipstick back in the tube the same way everytime, with the words facing the inside of the engine.
rsr50
12-26-2012 04:17 PM
mdfud
07-24-2010 10:12 PM
