The rear coil spring switcheroo...
Sorry, didn't tell you how. Unplug the sensors and remove them both, unplug the compressor (below the drivers side seat and bolted to the chassis) and tape up all the plugs. Go into the SLABS ECU and the BCU via the OBD2 plug with a read/write diagnostic tool and disable the SLS links and hopefully, if you are lucky, there should remain the ABS and TC but the SLS will be disabled as non functional. If unsure get a friendly mechanic at your local LR indy to do it as WNYErikDiscoII;507213 says ...................... but FFS don't forget to take the donuts
The Autocom can do really cool things, but nothing with suspension or chassis that I have yet seen. I got impatient waiting to do the ISS scan for all systems and canceled it. In the program there is a list of all vehicles it supports, and what all it can do on each vehicle, and since there is nothing about suspension or chassis in that list, I suspect it cannot.
b_woodroaster
11-05-2010 08:54 AM
southfloridadiscoII
06-18-2009 08:48 AM
