Rear crankshaft seal - Land Rover Forums - Land Rover Enthusiast Forum
Old 06-02-2012, 11:22 AM
Junior Member
Default Rear crankshaft seal
Hi all,
The parts for my rebuild should be here on Tuesday and I was just reviewed the workshop manual for torque settings and sequences, etc. looking at the rear main seal, I see LR indicates that special tools are required. Is this true? Are there alternatives to these tools if they are required?
If the stars align I'm going to pull the old engine out on Saturday and spend the rest of the day transferring the required bits over. Wish me luck!
Thanks for any help....
Old 06-03-2012, 07:25 AM
Junior Member
Anything?
Old 06-03-2012, 11:14 AM
Senior Member
Going off memory, the two "special" tools consist of a cone type thing that fits over the crankshaft end to guide the installation of the new seal lip over the edge of the crank, the other tool is a seal driver that sets the seal into place. I always used them when I worked at the dealer (because they were there) but I've seen others do it without them and think that if a person is careful it can be done. (other manufacturers I've worked for didn't have these tools and the procedure was the same). HTH
Old 06-04-2012, 05:52 PM
Junior Member
Thanks! I'll be careful and hopefully all will be well...
Regards,
Thread Thread Starter Forum Replies Last Post
crankshaft Seal install 2Much_DISCO Discovery II 6 01-29-2013 08:34 PM
Front Crankshaft Seal Hint humroot Discovery II 1 06-21-2012 10:51 AM
Front Crankshaft Oil Seal Leak LeakyDisco Discovery I 7 11-25-2011 09:38 PM
Remove Harmonic balancer to change crankshaft seal bosshogt Discovery II 6 01-01-2011 09:11 PM
crankshaft front oil seal JRdisco1 Discovery II 1 12-03-2005 10:19 AM
Tags
06, crank, crankshaft, discovery, install, land, main, range, rear, replacement, rover, seal, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
